I have written many times that I cant use my amps through the speaker because of the neighbours.
Anyway today I thought sod it I am going to try again so I hooked up my Dynamic mic put it close to the speaker cloth
and did a recording.
With the Amp turned up as loud as I dare the volume level was still very low.
On playback I used a Compresser to bring the volume up to a more acceptable level which wasn't too bad.
My question is,if I was to use a Condenser Mic would it give me more recorded volume for the same Amp setting considering it
needs 48v phantom power.
If not could you suggest a possible fix for my problem maybe a pre-amp would sort it?
Yes, a condenser mic will give you more level but there are drawbacks.
A dynamic mic on a guitar amp working at the "sweetspot" sound level is reckoned to be THE sound. A capacitor/ condenser mic will give a much wider bandwidth, and could sound fizzy and gritty. This could probably be mollified with software EQ.
IMHO a Small D cap' mic would be the best choice. Not as sensitive as the big jobs but still 10dB, 3x hotter than most dynamics. If you can run to it get one with a 20dB pad switch e.g. AKG Perception 170.
For perhaps THE best dissertation on recording G amps Google> Sound on Sound Aug 07.
Dave.
If you can't get a decent amount of level in the mic it's often better to record direct IMHO
Thank you for the replies.
I was considering the Audio Technica AT2020 which seems reasonable and gets a good review in SOS.
I was recording direct but everyone tells me the sound from a speaker is better so I wanted to try it.
So far I have only tried my Vox AC15 C1 but I will soon be getting my MJW amp and cab so I wanted to try it with
that setup before reverting back to DI.
Looks like its swings and roundabouts,i like the sound I get from DI Boogie 5/25 so I wont have lost anything
if this experiment does not work.
Bandcamp
Spotify, Apple et al
Hmm, you should not have a problem with that Focusrite interface. They are noted for having good pre amps and the 60dB of gain should be adequate even with the dynamic mic.
I wonder if you are trying to record too high a level? In the software the meters should read an average of -18dBFS and even as low as -25dBFS would be fine, peaks no higher than -8dB or so.
You can then bring that level up digitally and assuming you are running 24bits there will be no noise penalty.
You mentioned "compression"? Not really the way to increase levels. I used Samplitude mostly and in that you can "normalize" to any level of 0dBFS or below. No doubt the facility is in your DAW as well.
Dave.
