Then you can try to establish the key or at least the tone centre for each section.
Lastly in the "mapping out" phase, work out the chord changes (eg a bar of this then a bar of that, or two beats of this then 2 beats of that). Make sure you know where any sudden accents appear (on or off the beat).
After this you can work on guitar licks - which will make more sense in the context of the chord they are played over. Guitar licks naturally includes repeated riffs, fills in between vocal lines, and finally solos. But since you already have a chordal/harmonic "map" these things should be easier to suss in context.
But if you're going to use a tool might as well go all the way and get Transcribe! from seventhstring.com.
Feedback
Most YouTube instructional vids are pretty poor in my experience. There are loads which show the intro of 'Need Your Live So Bad' with instructors going to great lengths to stress it's all about phrasing. They invariably then go on to demonstrate that they have no grasp of it whatsoever.
To me, nailing the feel is absolutely as important as the notes.
I use Transcribe! but I always slow things down, if I can't make it out straight away. The approach you suggest seems good and I can see the logic in it. I'll give it a try.
