is there a reason why I can't. ..
TeetonetalTeetonetal Frets: 7818
Plug my head into a combo's speaker?
Speaker cables in combos are pretty short normally. Does anyone make longer ones. Spade to jack?
  • Yes, award session do, their website should point you in the right direction.
    Other than that, I imagine there are some people on here who would knock something up.
  • Tuscan777Tuscan777 Frets: 125
    edited February 2016
    I've done it at a push when the amp has issues
    Two rock nicely give you enough lead that you can sit a head on top for example
    You could get a locking extension cable. There is always a fair debate on risk of that . Personally I wouldn't have a problem as long as it was decent quality
    Easy enough to make your own. Just crimp a couple of spade connectors onto the ends of the wires. Obviously it would be best to solder them on but not vital.
  • Well I was thinking it's the ideal gig backup. If head fails combo is there ready to be hooked up...
    I do it the opposite way round
    If the amp in the combo fails I have a Blu amp 1 to plug in and get me through the night
    And it's saved my bacon
  • RiftAmpsRiftAmps Frets: 3184
    edited February 2016 tFB Trader
    I've made many speaker extension cables, I use them in my workshop all the time to connect stuff up, invaluable.
    All you need is:
    1 x Female 3/4" Jack Mono (£2ish)
    1 x Male 3/4" Jack Mono (£2ish)
    2m x Speaker cable (I use 2 core 6A mains cable) £1.90 per meter - longer if you wish.
    All this stuff is available in Maplins, solder it up and go!
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
  • hmm hadn't considered an extension cable.
  • jpfampsjpfamps Frets: 2734
    I use extension cables too, however I use the Neutrik locking female jack connectors.
    You really don't the speaker to become disconnected during use on a valve amp.
  • ecc83ecc83 Frets: 1641
    +1 with knobs on! A reliable quick and dirty solution is two (plastic) jacks soldered pin for pin. Bit of Gaffer, job's a good'un.
    Used to make up lots of those in 2, 3 and more ways for experimentals.
    Dave.
  • Rob at kabl made me this exact thing. I have a spare amp head that I take to gigs and if my main amp ever fails I use the speaker extension lead he made me (with neutrik locking female jack) to connect the speakers of my 2x12 combo to the head. Works a treat and the kabl stuff is great quality
  • 57Deluxe57Deluxe Frets: 7348
    you can - but has already been done before....
    http://41.media.tumblr.com/tumblr_ltsmc9sdWa1qasthro1_500.jpg
    <Vintage BOSS Upgrades>
