If you want to lower your running costs then it's a simple case of insulating your home and running your boiler in condensing mode which typically means modulating the flow temp down to 56 degrees or less. I don't believe that either Nest or Hive do this, so you are reliant upon the boiler manufacturers controls.
Modulating your flow temp requires a Modulating boiler (most new ones are) in addition to an external weather compensator (higher external temp = lower flow temp).
Skipped: Yes. I understood the description perfectly. But.....What is it for?
Engineer: Well.....when you get home, your house will be warm.
Skipped: But....when I get home, the house is still warm because of......Insulation. (points at Triple Glazed windows).
Engineer: I use it one hour before the end of a 12 hour shift.
Skipped: If you are working 12 hours shifts maybe it should be me giving you advice.
It's been displaced further down on my to do list by other priorities though.
Still by the time I get round to it the technology might have improved even more.
One thing to look out for is if any of the energy companies offer one as an incentive to switch to their tariff.
I haven't seen one recently but they were a couple of years ago. Obviously you pay for it still (probably not the cheapest a tariff) but it might suit you to obtain one that way.
EDIT:
Found this although I've never heard of that particular thermostat before and have no idea if the tariff is competitive and you are tied in for 3 years.
https://www.first-utility.com/cosy
https://twitter.com/spark240
Reddit r/newmusicreview
I guess they give flexibility / allow you to change the settings remotely when your work patterns change but for most people, running their boilers in condensing mode for longer will save money (that and insulating your house).
I have a temp compensation stay fitted to boiler as well as this and it's saved me quite a lot of money over the past two years.
Manchester based original indie band Random White:
https://www.facebook.com/RandomWhite
https://twitter.com/randomwhite1
I noticed hive now do their installations over 12 months 0% so you can get the basics for £20 a month.
I like the security idea of the electrical control as well - operating lights/wall sockets from your phone if you are away or home late to give the illusion someone is in the house.
I don't really need the sensors as we have an alarm. For me unless the sensors are integrated into some sort of camera it's a bit pointless...
is based on Thread an Internet of things standard backed by big tech names. Friends of mine have a startup developing Thread based devices for your home.
So down the road you may get access to the tumble drier That's Thread aware. So you home can be fully connected and controlled.
someone can correct me on the tech but that's my broad understandin
Love the interface and app though, am looking to replace our smoke alarms with the Nest ones soon too Maybe the new outdoor camera when that is available in the UK.
The thermostats allow automation and control from an app have inbuilt learning and location capabilities - i.e. we will know when you leave the house and turn off, be aware you are near home and switch on in advance. I think they also have temp gauges to override on unusually warm days etc.
