The short and dirty answer is...You would get distortion at progressively lower power levels.
In practice however this might not be ideal since you will be reducing the pre amp and PI headrooms as well as the OP stage and the result might not be optimum or pleasant, MUCH will depend on the topology of any particular amplifier I would think?
The only power control system I am familiar with changes just* the G2 voltage but even that in a far more complex way than a crude "variac" would do it!
*Well, not quite but I can say no more.
Dave.
If you have enough 'tronics smarts to separate out the heater supply then the G2 supply is as easy as a rule (2 Rs go to a cap) Then all you need is a small, few tens of mA variable HT.
Pentodes/tetrodes largely ignore changes in anode voltage but are hugely sensitive to G2 volts. If you dabble make sure you never accidentally remove the anode supply and leave G2 volts in place, pretty near instant valve destruction.
If of course your question was purely academic? Keep pinkies OUT!
Dave.
Heh! One of the very few amps you will see with an "anode" fuse* is the Series One 200..But! There is an interlock that shuts the G2 volts down if it blows.
*IIRC it is 1A FAST.Don't know WTF they bothered? It blows if a KT88 goes ape... and that usually takes out the 3.15A T mains fuse AND the 13A in the plug as well! Then, punters NEVER have a Fing F ffffuse in the gig bag and they fit any old s**t!
Dave.
Tinfoil out of a fag packet wrapped around the dead fuse or a bit of guitar G string jammed down inside the holder are the most common I think - or 36A car fuses in the days when both amps and cars took 1-1/4".
Thankfully getting a bit less common now most users are so unwilling to look at their own gear that they normally take it to a tech for a blown power valve and HT fuse...
Back in the Day.. A lot of mnfctrs of decent PA and related kit would include a fuse kit and a schematic, often stapled in a brown paper bag inside the gear.
Now everyone wants cheapy cheap-cheap, those days are long gone!
Dave.
The volume taper is also very home-friendly and doesn't have a step at the low end like many amps do.
