Pete Cornish once told me there are two types of 2 amp rigs;
1. a stereo which needs two amps the same.
2. A two amp set up.
Both are diff. I have a stereo rig, 2 tone kings. it's amazing and I prefer it to the two amp unbalanced approach.
Gives me all the valvey goodness onstage and Stereo XLRs for FOH
I'm the only guitar in the band so a big sound really helps (plus it feels amazing ... Gives me the Jesters toes)
Mind you, I'd be boasting about having a pair of TKs if I had. Mark Knopfler said to me they're definitely the best amps he's used....
But really I use two amps, I love it. I use one clean with all my effects in and one which is set to a crunchy sound.
I find that I can get a great deal of depth by having a clean amp and a driven amp.
Wos an amp then nahahahahahahahaha
Before collapsing face first into a pile of chips with curry sauce
i have the matamp with more mids and little hair and going through a 4x12 and have the marshall (Superbass) set up with more bottom end and going through 4x10 bass cab.
together they sound very big and thunderous.
Rambler one side - Lazy J the other. Mind blowing, esp with the FX8 and ehx 45000 - panning sounds either side !
I don't tend to solo using both amps though. I chose one or the other to solo or both to thicken up things like a special effect.
Bandcamp
Spotify, Apple et al
True that ^.
Even now most true multi amp set ups (as in more than one amp actually on at a time) you see nowadays are again two different amps running in mono often say one mid-humped and the other mid-scooped.
I like the effect you get when you've a trem or delay set quickly on a clean amp but have the drive of the other amp. Instant "what's the frequency" tone.
