I was setting up a new pedal set up with my Egnater tweaker this evening, trying to work out which pedals/power supplies were causing noise. I noticed my amp go quiet and the kind of ticking noise you get when an old fashioned lightbulb goes.
When I investigated I noticed my amp was set to 4ohm when the speaker is 16ohm. I have no idea how long it was like that, it could have happened when I was setting up the pedals this evening, it could have happened when I recently changed the pre amp tubes. I still have the previous pre amp tubes that I know work, swapping them did nothing. I tested both the power tubes in my fender champ, one still worked one did not. When I put the working one back in with the working one from the champ it still didn't work. So I know I have done something that has blown a tube plus done some other damage. What is the best and worst case scenario here?
I love this amp but it is cursed.
Worst case is that you've also blown the output transformer, but very unlikely if the amp was not turned up loud.
Somewhere in between is that it's possible the blown valve also took out another component, but not the OT - eg a screen resistor or power supply chain resistor.
It is also possible that it's pure coincidence and nothing to do with the impedance mismatch - valves can sometimes fail for no obvious reason.
sorry I missed this post. thanks, I will follow this procedure.
I think I worked out how the Ohm switch got flicked, I had very short leads for the send/return which were pulled quite taught as I moved the pedalboard about, if I moved across it could have clotheslined the switch.
Eqd Speaker Cranker clone
The 40W one in the shop has a cooked power transformer by the way... although I don't think yours will be that if it's blowing the HT fuse not the mains fuse.
