Do get the old solder off if you can and do use braid. I have found suckers to be more likely to damage print and suckers take some "larnin"!
Once de soldered scrape the tags with a sharp model knife blade to get to fresh metal.
This is a common problem with PCB mounted jacks, DINs dah di dah....BTW lead 60/40 is fine and best.
Dave.
Thank you!
