I have done this for a single ten in place of a twelve.
I cut a sub baffle which attached via the original T nuts and the 10 was front mounted to that.
This puts the ten's cone in about the same plane as the original 12 as some folks have deemed this important even for guitar speakers! I am far from convinced but it is as easy to do as any other way so what the hurt?
Dave.
"I'm not sure whether keeping the cone in the same plane matters, but I think front-loading vs rear-loading does make a noticeable difference - although that's purely anecdotally from experience and I could easily be wrong"
Hah! I once made an innocent comment to one of the directors (who also had very good "amp ears") to the effect that front loading drive units was a standard almost everywhere EXCEPT for gitcabs.
I was Torn to Sheds! "Sounds 'effing horrible!" "Never front load speakers, wrong, wrong, everso ****ing WRONG!"
I still suspect it was "because that's the way we have always done it...." is more the answer! Shoot! Celestion even give you front mount gaskets!
Dave.
