I'm currently working with a band basically doing Indie (ish) stuff so probably need an AC30. In the absence of that, I've dug out my Subway Rocket Reverb which has a twin EL84 output stage and can do a reasonable imitation of the Vox sound. The amp is, however, getting on for 20 years old and is getting a bit hissy so I thought it would be a good time to swap out the valves. Due to the fixed bias setup, I guess I'd better stick with Boogie valves for the output stage but I wondered if anyone had any recommendations for the rest, which are currently 12AX7s.
Bearing in mind I don't do metal and I'm looking for the cleaner/jangly end of the sound spectrum any input/advice gratefully received. I'll be using my American Std Tele if that helps.
I replaced the link wire which feeds the tone stack with a resistor, which has lowered the overall gain and reduced the mids a bit too. The link is roughly behind the treble control and runs front to back in the amp - I replaced it with a 470K resistor.
(On the non-reverb Rocket it appears to be a 100-ohm resistor rather than a link wire. No idea why since the value is too small to make any practical difference!)
@ICBM actually, since there seem to be 3 of us all with Rocket Reverbs, I might as well ask about something that has been bugging me.
On mine, on the crunch channel, the gain control will reduce the gain (and volume) as you turn it down until it gets to about 2, where the gain hits a minimum (but still not clean). Then as you keep turning it down to 1 and then 0, the gain actually increases slightly and stays at a slightly increased level all the way to 0. This means with the gain at 0, it will have more gain than with the gain at ~2.
On the clean channel it behaves as I expect - as you keep turning the gain down, it will get less and less gainy until you hit 0, when it practically cuts the volume off.
Is this normal or do I have a dodgy component somewhere?
