So I recently bought a couple of speakers which turned out to faulty - one's got a warped cone and sounds a bit growly in the low end, the other one crackles horribly at any volume. Seller was very quick to refund me and told me just to keep the speakers, so no quibbles on that front!
That does however leave me with two broken speakers sitting round at home. They're Mesa mc-90s, so I think getting the actual Mesa cone assembly will prove pretty much impossible. I spoke to Celestion who said the best bet would be the CL-80 recone kit, at which point I'm guessing they won't be MC-90s any more but at least they'll work and presumably still be pretty respectable.
Question is, has anyone here done a recone themselves? Is it hard? easy to screw up? The kits are available, I was considering doing one as a test then the other if I was happy with the result. I guess I'm also wondering if it's even worth it - at the moment I'm not out anything, if I try and fix them and they sound rubbish I am!
Fwiw not all speakers can be repaired by reconing. If you have a 'warped cone' that usually goes hand in hand with a warped chassis. So check it is not bent. Not unusual if you buy loose speakers on ebay because people are always crap at packing them and they get damaged in the post. Celestion chassis are very soft and it doesnt take much to bend them out of shape.
Damaged magnets etc, also cannot be saved by reconing.
If you run a hire business and are likely to get some practice regularly then yes have a go. It's not so much difficult as requiring care and patience. Cleaning off all the old glue, cleaning the magnet gap, getting the spacers aligned then glueing the new cone in place accurately and leaving it to set. You'll save about £6 a cone if you get it right iirc.
Changing diaphragms in horn units is usually easier because they are rarely glued into place.
Bandcamp
Spotify, Apple et al
I'd list the speakers on eBay as in need of repair with a 99p start price shipping cost on top and let someone else take a punt on being able to get them fixed.
If they don't sell you're no worse off, you've already got the packing to send them out so anything made is profit.
<○> Big Norm Feedback
http://www.ebay.co.uk/itm/Mesa-C90-Celestion-Black-Shadow-8ohm-Uk-made-speaker-/231863558337
If you buy that speaker make sure you tell him how to pack it properly. If he is just going to tape that box up that its photographed in, then it will arrive damaged.
