Still on the hunt for a flexible, big sounding amp for my band... Happened across one of those Blackstar IDV 260's yesterday and to be honest it sounded really good. Loads of sounds and a few effects built in, and very very loud - We cranked the volume to the max just to see what it was like and it nearly took my head off....
Has anyone here got experience with gigging one? Other guy in my band has a Blackstar HT40 and that sounds really big so i need something that can match it really. Only concern with the ID260 is it might seem a bit 'flat' maybe when cranked up and in a band situation.
Thanks
If he has heard one ICBM will I am sure give you as "Tonal critique" of the 260!
As far as welly goes, the HT-40 is a good amp as you would expect me to say but not perhaps THE loudest* 40/50 watter around? The 260 therefore should have no trouble keeping up with it.
One limiting factor with the 260 might be the speakers? Have you considered an ID 100 head and cab? Unlike perhaps a 100W valve head, a pair of V30s 8R would be pretty safe on the ID100 but of course you would have a vast choice of speakers..
But even IF (and I don't believe it for a moment) the tone was slightly compromised, it is never likely to go wrong!
*The HT-60 Stage on the other hand!!!!
Dave.
Yeah i gig with one.
The dual speakers and fx section both bring a level of redundancy which is good (e.g. if my pedal board dies or one speaker dies, the show can go on). For the money it sounds great and is robust (I think @ICBM said once that they shorted the outsto ground and it still didn't die).
I preferred the sound to the valve amps I tried. No worrying about changing valves. Still heavy to me but lighter than valve amps. And it's plenty loud enough and takes effects well.
I've not played many valve amps so I'm a little biased.
My YouTube Channel
My YouTube Channel
My YouTube Channel
My YouTube Channel
My YouTube Channel
Check with B's about that footswitch logic!
The switches are symmetrical squares. two pole c/over IIRC. If they are stuffed wrongly in the PCB they exhibit this problem (and I am sure it is a problem).
I had this on one of the first 2nd gen' pedals with the new switch regime.
Dave.
No mate! I am assuming the switches are the same as in the gen 2 pedals, i.e. a small "computer" switch with a barrel assembly above it (did I tell you the tale of the super rugged, quite costly early switches 'king up?)
The switch has an ident mark but they are not foolproof (I assume when bandolier, robot fed they cannot go wrong? Doubt these are) .
The insidious thing is, if "they" get them wrong the circuit still works after a fashion!
The assumption is that computer kbd switches seem to last millions of ops, the tops come off but the switches still work!
Dave.
