Digitech Harmony man AND the Digitech RP1000 can it work ?
ConkerConker Frets: 2
edited March 2016 in FX
Can anyone point me in the right direct.
Is it possible to use the Digitech Harmony man AND the Digitech  RP1000
With the 4 cable method.
There must be a way surely to allow me to use my amps drive channel.
I can 4 wire the Harmony man straight into the loop and it sounds ideal for what I want much better than the RP1000 harmony.
However when I try and place it in the stomp loop of the RP it sounds awful like a crap octivator.
 I am guesing the stomp loop is feeding the signal pre not post.
Any ideas or advice welcome .
Cheers
  • english_bobenglish_bob Frets: 5164
    I haven't used one, but I suspect that the stomp loop on the RP1000 is for patching in external effects that you want to hear in front of the amp, which is why it sounds different to having the HarmonyMan in your amp's effects loop.
    Try setting it up so that the Harmony Man is connected between the amp's effects loop send and the RP1000's "amp loop return". That'll put it after your preamp gain, but in front of any modulation or delay from the RP1000 (which would probably sound like ass in front of the pitch shifter anyway).
  • ConkerConker Frets: 2
    cheers
