... to a point.
I've realised recently that when I've been chipping in on the Lava vs other vs whatever conversations that I probably wasn't comparing like with like.
My issues with Lava seem to have been with the ELC stuff, whereas the current 'Tightrope' system is, as far as I can make out, identical to the EA SIS system. Having taken delivery last night of some Tightrope stuff, and watched the instructional vids on both that and SIS I conclude that the way they work and assemble is identical - anyone used both and able to advise to the contrary?
Same seems to go for the even newer Lava Piston plugs compared to the Free The Tone system - appear to operate identically...
So it looks to me like that 'SIS is better than Lava' forums conversations around the net are true if to add "...ELC" to the end.
Thoughts?
Red ones are better.
The lava piston is a bit more complicated to put together, screws can go missing, the cable itself is bulkier but so far so good.
custom pedal boards only use the ea sis, and have done since they came out.
reason being its better, in my opinion.
the cable feels better as do the plugs.
the lava cable is actually a fraction of a mil thinner which means it waggles around in the plug when making them, the monorail does not an is a much more solid fit. as for the quality of the copper and other materials used, who knows which 1 is better but the little evidence pixies assure me that the ea cable is higher quality.
the sis plugs have a much nicer feel and quality than the lava plugs which have a shiny plastic feel to them, also the knurled ends on the lava plugs play havoc with your skin, the sis plugs dont (well less anyway)
i have made hundreds even thousands of sis patch cables now, and are the only choice for solderless patch cables, and the extra cost is worth it as far as i'm concerned.
there u go, take it or leave it.
Evidence Audio SIS are far superior, more rugged, durable and just overall a much better quality product. My guitar friends have since moved over to EA SIS (on my recommendation), and have never had any problems.
Cheers..
Laurie
In the end I spent almost half as much on Lava pancake jacks and 2m of lava cable and soldered them myself. Not had a single noise problem since and wasn't difficult to do - found it easier than the Solderless Lava system!!
