You can get a cheap and cheerful set of wire strippers for 3 quid on the bay/amazon
http://www.designacable.com/components/connectors/hicon-stereo-pancake-jack-hi-j63sa05-flat-angled-gold-tip-black-silver-shell.html
Nil Satis Nisi Optimum
I did a little photostory when I put my pedalboard together. I should probably put these in order and save it! These are all Sommer Spirit and Neutrik plugs but the principles are similar.
1) My tools of choice for this work. Skinny solder, needlenose pliers, cable cutters, scalpel, flush cutters, pair of mole grips, solder station and brass shavings tip cleaner.
http://www.monkeyfx.co.uk/pictures/pedalboard/cabletools.jpg
2) Tin the relevant surfaces on the plug - a tabletop vice helps with this.
http://www.monkeyfx.co.uk/pictures/pedalboard/plugtinned.jpg
3) I hold the cable (with the boots already on) in a pair of Helping Hands that have had the teeth bent flat:
http://www.monkeyfx.co.uk/pictures/pedalboard/cablemaking.jpg
4) Remove the outer shield, neatly twist off the shield and tin it:
http://www.monkeyfx.co.uk/pictures/pedalboard/shieldtinned.jpg
5) Trim the shield, strip back the semi-conductive layer and the core insulation, then tin the tip:
http://www.monkeyfx.co.uk/pictures/pedalboard/tiptinned.jpg
6) Solder the shield to the plug:
http://www.monkeyfx.co.uk/pictures/pedalboard/shieldsoldered.jpg
7) Solder the tip:
http://www.monkeyfx.co.uk/pictures/pedalboard/allsoldered.jpg
And then close the plug up.
