Tim's Twisty Knob!
Flanging_FredFlanging_Fred Frets: 3104
I'm having a bit of an issue with my Tim overdrive pedal: the knobs on it turn really easily and I keep knocking them out of position in rehearsals. This is getting on my tits a bit.
Is it possible to tighten up the pots or some other solution other than just banging a load of gaffa tape on them?
  • meltedbuzzboxmeltedbuzzbox Frets: 10340
    Gaffa will effect the tone!!
  • Flanging_FredFlanging_Fred Frets: 3104
    I only use boutique gaffa tape. It makes a huge difference. Pricey though.
  • ThorpyFXThorpyFX Frets: 6222
    you can buy tiny rubber o rings. Put them over the shaft and press the knob down onto them then tighten. This gives enough friction to pre by the knobs slipping around.
    Adrian Thorpe MBE | Owner of ThorpyFx Ltd | Email: thorpy@thorpyfx.com | Twitter: @ThorpyFx | Facebook: ThorpyFx Ltd | Website: www.thorpyfx.com
    ThorpyFX;1062359" said:
    Flanging_Fred said:
    meltedbuzzbox;1062339" said:Gaffa will effect the tone!!
    Like a small gromet type thing? That might work, I'll see if I can find something...
    Thx for the idea :)
    Thx for the idea :)
    thats the badger!
    I bought a box of O rings at B&Q for next to nothing and as Thorpy says, they work a treat. I use them on most of my pedals because once they're dialled in I tend not to change the settings.
    Just a quick thank you for the replies. I bought a 99p pack of rubber shower hose washers from Robert Dyas. They do the job perfectly. Cheers.
