Yus, you can always play around with resistors to change a load/power soak to another impedance.
You can get 100W alllyclad Rs in almost any value (but as IC says, not critical) and these can be put in parallel or series as required (series will of course insert a permanent loss).
But!! Always check here with ICBM that your proposed load kludge is 1) Safe for that particular amp and 2) That it is likely to sound good.
You can use the same stunt to allow the use of a speaker of marginal power rating on a bigger amp, e.g. slapping 16R across a 16R speaker will virtually double the power handling. Amp set to 8R of course! Again, check with the guru over the border that you have the sums right. The sound will be changed a bit of course but not drastically methinks? Depends on the gear again of course.
Dave.
