I think it only uses the second ECC83 preamp valve with the Boost circuit. So switching preamp valves might help me rule out a bad pre valve?
I've got a JMP1h as well and that uses the same 2 x ECC83 preamp valves so having spares won't hurt if it turns out to be something other than valves (which seems likely). Then it will be off to a pro tech. There isn't much inside these so I'm sure the issue would be tracked really fast. Great little practice amps though.
Jeez your guys are some help!
Andy
