Flexible patch cable
zepp76zepp76 Frets: 2534
I'm having trouble using my standard patch cables and was wondering if there is a more flexible cable, or one with opposing jacks that would allow me to plug into a pedal with input/output on the top to a pedal with input/output on the side? My 6" cables just aren't flexible enough to twist to allow me to go between said pedals without damaging them. Any ideas chaps?
Tomorrow will be a good day.
  • Winny_PoohWinny_Pooh Frets: 7819
    If you use a solderless system then you can place the jacks at any angle to the cable bend.
  • dogloaddogload Frets: 1495
    I make my own using the thinner cable from cheap guitar leads (the really cheap sort with moulded plugs). They are very flexible and are fine on a pedalboard where they are not being continually plugged and unplugged.
  • paganskinspaganskins Frets: 276
    EBS' patch leads are very flexible, the cable has an ovalish cross section and the jacks are very low profile. They're designed as space saving but also seem very easy to work with.
    My only complaint is they don't do anything between 28cm and 58cm.
  • SporkySporky Frets: 28785
    Sommer Spirit is very bendy.
