No it is not a VGA cable. They have 3 rows of pins (and are SODS to wire!).
That is a 15pin "D sub" and if it is a simple "all pins wired" jobbie you should be able to find one on the infernalnet.
Push comes to, give Blackstar a bell. The Series One FX cable is a 15 pin APW piece and I cannot think Marshall would wire one any differently?
Dave.
HAD not noticed the female ends!
But though t that might be an "example" and not THE cable in question?
The S1 cable is M to F so looks no used to you unless you get a gender changer.
In B's defence, that is a "standard" cable if a little hard to source!
Dave.
I'll be surprised if you can find one off the shelf.
The biggest problem for practical live use is the total lack of programmability, you're essentially limited to one sound unless you have a photographic memory for the many control settings.
And I'd still want a spare cable if I was even going to think about owning it...
Frankly I wouldn't spend a lot of money on it since AVTs are not exactly renowned for reliability.
If it is you could do this:-
http://www.ebay.co.uk/itm/Gameport-Extension-Cable-DB15-male-to-female-5m-/351673204453
http://www.ebay.co.uk/itm/DB15-Pin-Male-to-Female-Gender-Changer-Converter-/301684871884
but if the official spare is £20 - £30 I'd probably get that instead.
