NOT! That I am offering Pete! (my soldering days are passed) but can we pin the design down a bit?
Do you already have a 16 Ohm load box? I assume not but then the builder will need to know the amplifier brand and model to get an idea of the ultimate power it could put out, e.g. "our" Stage 60 comfortably kicks 80watts and seriously overdriven would deliver near 100W.
The line out? Level? +4dBu, 0dBV or neg ten? And at what amp volume level do you want that OP level? (easiest to make it variable)
Gets tricky don't it?
Dave.
About £80 seems right then. I can also do this for you.
I really wouldn't worry about a MBB switch Dan. In hundreds of amp testing hours I have had rigs that flipped speakers/loads scores of times on each test, often with the amp at full welly. Then there have been the chance "unloadings" under sine or noise drive, again often at max crank.
I you are REALLY concerned you could have a permanent load of say 3X the rated LS impedance connected or just a 220nF or so cap across the live contacts of the switch.
Err Mr A, does that 80 quid include my commission?
Dave.
