Hey guys,
Might be a stupid question, may be a simple answer, but I've just got my second amp (Marshall DSL40c) to go with my Hughes and Kettner Tubemeister 36, and I'm not 100% whether I want to play stereo or wet/dry. I've got pedals with very good analog dry-through signal, so I'm thinking I might be able to get away with stereo. However, when playing live I might find I'm not cutting through so will want to play wet/dry to make sure.
Is there a pedal which you can switch between having a wet/dry and stereo? Or is there an easier way of routing to make it possible to switch between the two? Got an active ABY coming with isolation and phase reversal, so I'll be fine for routing a wet/dry sound.
Thanks again, hopefully there's an easy solution!
My music:- https://soundcloud.com/hubobulous
