I have a Weber 5e3 kit that I built a few years ago. The output as per their standard schematic has a green wire providing an 8 Ohm connection to the output socket.
I would now like to use a 16 Ohm speaker. There are 4 wires in total exiting the O/T: Green, Yellow, Orange and Black. Is there a convention (that I've not yet found on line), as to which colour is which tap from the O/T. In other words, which is my 16 Ohm connection?
In fact, what makes things more confusing now I have visited the Weber VST website is that some of (their own) transformers have the green being 4 Ohm and the 8 Ohm being yellow!!
Thanks
Now, first off. Do NOT tell me you are forking about with amplifiers but do NOT have a digital test meter? You are NOT telling me that? Good, so.
You know the common colour and the "hot" 8R wire. Connect the meter to the common wire and on Ohms short the other test probe to that tag. The meter will read the test leads loop resistance, usually 0.2 to 0.5 Ohms.
Now test each colour in turn making sure to get as good a connection as possible (maybe sharpen the probes?) and note the lowest resistance found.
As you might have surmised by now, common to 4 R will be the lowest reading and 16R the highest.
BTW. If you have a totally unknown traff you can feed heater, 6V into the speaker side and measure the voltages at the primary so finding the ratio(s) . Bit of Ohms law and transformer 'rithmetic gives you the loadings and thus the valves it would suit.
Dave.
I have also emailed Weber, an whilst they responded yesterday (which is impressive in itself), none of the O/Ts that they describe is the one that they included in my kit!
That said, I'very been using the amp with an 8 Ohm speaker for the past 5 years, so I guess that the green wire is the 8 Ohm tap.
I'll get the meter out when I get home and report back.
Thanks
