You could have it biased a bit cooler if it's worrying you.
I probably will get the bias adjusted (with the associated mod) at some point. Just need a month when I spend less on the classifieds here :-)
Yes, valve amps DO get hot! Some folks that have never had one don't quite get it.
I recall an Artisan 30 combo shipped back because "the front plate gets too hot to touch". Well it did, just, after about an hour but the valves were on specc for anode dissipation and the way the chassis is fitted causes the heat to rise to the top of the amp (the FP of the A30 head runs cooler) .
NASTY! HOT! INEFFICIENT things valves! Glad I am shot of them!
Dave.
like this picture
If you want the amp to run cooler you could install a small fan, it would probably make the electronics in the amp last longer.
(They look so pretty though)
I had a Tubemeister 18 that you could fry eggs on. I've a Marshall JCM900 1x12 that you'd never know was switched on. The MESA Minirec is somewhere in between. All of them funcitoned absolutely flawlessly. So what that tells the uneducated (me) is that it really comes down to the case and chassis design I guess.
While it's true that they don't normally have output transformers - which saves some weight - a solid-state amp has to be typically two to four times the power of an equivalently loud valve amp, so it then needs a much bigger power transformer which removes most of the advantage.
If you don't believe me, try lifting my Peavey Special - 120W, and about the same volume as a decent 50W valve amp. It actually weights 1lb more than my Mesa DC-5 did - partly because it needs an even bigger speaker to handle that power.
I admit modern solid-state amps with switch-mode power supplies can be much lighter.
I know the Marshall could bury the Crate in terms of raw volume despite the SS amp having three times the output on paper, but either amp is too loud for my gigs down the Dog and Duck so it's kind of moot I guess.
Basically as soon as 'they' nail the dynamics with an Axe-FX and the price drops to £500 (don't laugh, it has to be that cheap one day!) I'll be using that with a switched-mode-supply power amp and some feather-light cab with neodymium speakers and valves can bite my shiny metal wotsit (I miss Futurama). I have no affection for valves whatsoever, @ecc83 is right (whether or not he was joking!).
And as the OP's helpfully illustrated, you're forever worrying about the damn things. Is it running too hot? Can I move it yet? Let me check for the 17th time I plugged the speaker in before I hit the 'standby' switch...
