You could by a pedal snake cable with the appropriate tails
Do you want to switch the delay in and out of the FX loop or actually remote the switch on the delay?
The former just need a box, 4 jacks and a changeover switch (get a bit more complex if you want a LED status indicator)
I have no idea what the internal switch in the Boss is. If it is as I am used to, one that flips FETs with DC it could be extended many metres. I would use shielded cable, 2 cores min and if you need multicore go beg some FTP 4pr patch cable!
Dave.
http://m.ebay.co.uk/itm/NUX-PML-2-Mini-switcher-pedal-A-B-line-selector-switch-true-bypass-/301913886888?nav=SEARCH
[/quote
Price Looks good an worth a punt. I've sent an email to bright onion. Gigrig looks excellent, high quality and of only a used one was available ... Thanks for all the input
Can't find a schematic for the "7" but the earlier delays just switch a pin on the big chip to ground via a CR network.
Should therefore be simple to kludge.
Dave.
