If or when I use my back up system: Guitar > Pedalboard > Sansamp Tech 21 British > D.I Box > P.A(Mixing Desk), it is obvious that I will hear very little of my guitar on stage as it will be coming out front of house. Our band has 2 monitors which seems to suffice in normal circumstances(with my amp working). One is placed in front of the singer and one near the drummer. I have my amp for reference on stage.
But if I use my back up will I need a passive monitor or a powered one?
Doesn't need to be anything flash, something between £100 - £150 and preferably small but mighty
Only a Fool Would Say That.
If you want extra just for you back up then it might as well be a guitar amp but for the, hopefully, rare times you'll need it then I'd just rely on the pa.
You could plug into these first (giving you just your guitar sound) and then connect the output to the PA or you could feed a signal from the PA to them giving you your own personal mix. They have 2 inputs so can be used in a variety of ways.
