Check the HT fuse first if there's an external holder for it.
"No, bit hard as I can only test in a flat..."
Cannot offer specific help but a plea to anyone who might attempt such a "first line" repair? Knock up a basic load box. If you don't need pretty you could build a 100W load for about £20 thus allowing full power testing of most amps without waking the chavvy.
You might think you need a monitor speaker and the associated circuitry and that indeed would be nice but, driving 30-50 watts into a load will cause the OPT to "sing" so you will hear if it stops! You should in any case have a test meter so that on 100V AC range will show operation.
Dave.
