A friend of mine has a late '50s Champ which he got super cheap in Australia years ago. I was round his the other day and had a look in the back of it for the first time - it still had the death cap to ground, and no mains earth! Also, he was running it through a woefully underpowered stepdown transformer.
So I said I'd make it safe for him, which I have done. However, it is making my dim bulb tester glow pretty bright. It glowed a bit even with the amp off, so I thought it might be down to the step down transformer. All the voltages were proportionally as expected, so I thought I'd try flipping the switch with no dim bulb - TRANSFORMER BUZZZZZZZZZZ. I turned it off pretty damn quick.
Anyone know what the issue is? I am thinking that one of the transformer earths needs to be disconnected, but that's just a hunch. I can't find a relevant thread anywhere. Arse.
(formerly miserneil)
Although not good practice, having a stepdown autotransformer connected wrongly shouldn't cause a problem because both live and neutral should be isolated from the earth in the amp.
What I meant was to swap the live and neutral at the *amp* transformer.
Don't try it without your current limiter in line until you've isolated the problem. If it was pulling current even with the amp switched off that isn't a good sign.
Do you have a multimeter? I hope so if you're doing this sort of stuff! If so, first measure the resistance from the transformer winding (either live or neutral) to the chassis. It should be an open circuit.
Yes IC I also suspect he has a primary to frame leak. The problem is a DMM might not show it, such faults often need a few tens of volts to break down (but who has a Megger these days?!) .
Taking THE GREATEST CARE he can put a lamp in the amp chassis to good earth path. Even if it does not light, the presence of more than a volt or two across the lamp would indicate a leaking transformer.
Jusfort! Does the amp have a single pole mains switch and if so are you SURE it is in the live side?
Dave.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
