FS Bell and Howell Filmosound Projector Amplifier £200
blindblakeblindblake Frets: 2
edited September 2016 in Amps £
This is a Bell and Howell projector amp
comes complete with all tubes and fully working
you will need a step down transformer to convert UK / US voltage
has been fully serviced.
  • billzabozobillzabozo Frets: 62
    What is the power output, what valve combination has it got & what ohm speakers does it pair with?
    Cheers
  • its 20 watts
    its 2 x 6V6 - I ll find out tomorrow the other tubes
    it has outputs for 8ohm and 16ohms
    thanks
  • SparksSparks Frets: 29
    I’m after one of these if anyone has one.
  • I still have this one but not for sale I'm afraid.
    Check out oldamps.weebly.com if you've not already done so. They did the original conversion on this one. If you can pick up an original projector cheap they can do the work & it comes in a bit cheaper than buying a finished article.
    Good luck with the search, they are worth the effort.
    Thanks for the info. Any particular projectors that work, or can all of them from the same vintage be converted?
  • I'm not technically gifted enough to say which models are suitable although it's not all of them. The 385 is the desirable one mine is a 621 which doesn't break up as soon and I believe the 185 model also works but beyond that my knowledge is usless.
