I plan on having the FX LOOP SEND / RETURN row on the top of the pedal board.
My YouTube Channel
OK good. Basically all I need then are 6" patch cables.... I don't ever need to connect the top row to the bottom row.
My YouTube Channel
R.
Eqd Speaker Cranker clone
Even just on leads and patch cables alone!
My YouTube Channel
what is the boost pedal in the fx loop? is it a transparent clean volume boost?
Effects for Me & my Monkey YouTube channel Facebook Fretboard's "resident pedal supremo" - mgaw
My YouTube Channel
amp < TU2 < OD < Comp < Wah < Ph90 < guitar
return < Vol < Chorus < Delay < send
http://i865.photobucket.com/albums/ab217/Vizzage/Mobile Uploads/image_zpscqmnegah.jpeg
My YouTube Channel
Yes, it would stop a bit of hiss.
Yes, it would buffer the signal into the amp reducing the chance of switch pops.
Yes, it acts as a trouble shooter - if you've got no signal coming out the speakers you can see if the guitar signal is at least making it through your chain.
No, I can't bring myself to do it.
TC Dreamscape Chorus.
TC Flashback Delay (I rarely use it, if ever)
EP Boost always on. TC Spark for clean boost.
FX loop.... er, I'm not sure! Aren't they all instrument level?
My YouTube Channel
My YouTube Channel
Not all loops are effects level. Test with your pedals to see if they clip.
Never put an overdrive in the loop!
Do I go Back to the Future?
What's the deal with effects/instrument/line level FX loops?
My YouTube Channel
I set the clean channel and everything goes in the front...
My YouTube Channel
Bad things can, and do happen to amps.
You remember Stay Puff the Marshmallow man from Ghostbusters? Like that, but inside your amp........
Keep OD's/Distortions in front of the amp.
A clean boost will be good to go in the loop.
Ok, thanks
My YouTube Channel
