Close enough! Have a listen to this
https://www.youtube.com/watch?v=s6wqvpB1M2U
(in terms of price)
see.........I've got a Timmy at one end ( last in line of ODs) of my board for that nice clean, transparent volume boost
and I have a barber Gain changer on 1st.....so I can have my main OD (Minstrel pedal) either boosted with the Timmy or goosed a little from the GC in front......
I was just wonderin' if the Minstrel would benefit from being "goosed" a little by a OD808 (TS) or a SOUL FOOD job....?
I've had an 808 of course but never a Klon klone
If the numerous comparison vids are to be believed the soul food seems almost identical to the real thing. Maybe there are klones out there that actually sound better than the klon?
I don't know if they're all different or something, but the one I tried was quite nice as a clean boost and pretty rubbish as an actual overdrive. To my ears at least.
It was the kind of gear you'd imagine might complement such a pedal, and it did sound pretty nice as a clean boost - fattened up the clean signal nicely and added some nice compression and sparkle, but the higher up the gain went the less convincing it was. The gain doesn't go up very far anyway, even maxed out it's like a Tube Screamer with the gain at about 3. It just sounded a bit fizzy and like the wrong sort of clipping was going on. Definitely not comfortable being an overdrive.
My dad has a Rockett Archer which is similar. Not my thing... I'm not a gain freak but I like an overdrive to have a bit more on tap.
Soul Foods ok within limits, cheap enough to try & flip, I even made a whole quid profit. Got two klon pcbs to build up now.
The YouTube stuff I've seen seems to suggest you have to dial them all in differently to then get the same sound so the Soul Food needs experimenting with. People seem to really like the Tumnus but it isn't, apparently, the most accurate Klone - just has some of the fatness the others are missing.
I own a Soul Food. It cost me £35. Does the same thing, not identically, but is it close? Yes. Is it worth £35? Yes.
I wouldn't pay more than £100 for a real Klon, let alone the figures they're advertised as these days. You're paying for hype like Dumble and Trainwreck, nothing more. There are better choices.
If I need the dirt, I got a Way Huge Green Rhino. Axed the Bad Monkey. The Soul Food/Green Rhino combo is one I'm gonna be holding down for some time to come.
I think they have two uses, firstly as a clean boost and secondly as a TS style overdrive with a little more glass and a less obvious mid-hump
I really enjoy the pedal, and I like it a lot - is it really worth the money? Probably not - my ThorpyFX gunshot has more versatility for about the same money.
I'm on the waiting list for a King of Tone to replace the one my ex made me sell. When it turns up, I'm not sure if the Klon will stay
But then I don't use it in isolation. For fattening up an already crunchy sound, it's really nice, regardless of price, I think.
