Oiling an acoustic?
I gather that a manky fretboard can be rejuvenated by applying a little lemon oil. Does the rest of the guitars wood need to be oiled at anytime during it's lifetime. I like the smell of my cricket bat.....could I put linseed oil on my guitar?
  • Winny_PoohWinny_Pooh Frets: 7771
    edited July 2016
    The oil is for the unfinished parts like fretboards that may get dry, linseed is a bit thick. So no, unless you have a Musicman style tru oil waxed neck, you don't.
    Raw linseed could be used but takes ages to dry so I don't use it.
    Boiled linseed is better.
    Lemon oil is my preferred option.
    As Winny says you shouldn't need to oil any other parts.
  • richardhomerrichardhomer Frets: 24807
    edited July 2016
    I wipe the ebony bridge over with lemon oil when changing strings.
    But I am weird....
    Linseed can be sticky and attract dust but, you're right, it smells wonderful.
  • AliGorieAliGorie Frets: 308
    edited July 2016
    lightly walnut oil f/board and bridge allow to soak in and burnish off with rag.
    Sainsbury's Walnut Oil 250ml £1.60
    1reaction image LOL 0reaction image Wow! 3reaction image Wisdom
  • NiteflyNitefly Frets: 4918
    Wis from me, except I get mine from Tesco.
  • TCatTCat Frets: 26
    If the fretboard is really manky, you might want to give it the lightest rubdown---only between the frets, not on them-- with the finest grade wire wool you can find......then a small amount of lemon oil, applied with fingertips, then rubbed off with lint free cloth. Been doing that for years...works for me. While you're doing that, get a pencil and work some lead into the nut slots--wipe clean and drop in a tiny bit of lemon across the slots too.
