Orange Tiny Terror - fit an Effects Loop
just picked a used one of these as a backup but it sounds so good i would like to gig it. Need an effects loop though.  Has anyone had one fitted? If so his much and who did it.  Thanks
  • ICBMICBM Frets: 72822
    It can't be done properly because it has a post-PI MV and generates a lot of the overdrive from the PI, so you can't put the loop where it needs to be to work correctly.
    The Dark Terror - which has a loop - has a completely different circuit with two more valves, a normal post-preamp MV, then the loop after that, then the PI.
    Thanks - worth the ask though.
    Freyette Powerstation will add a loop and beef up or attenuate down the power as needed
    or spend the same money and get an amp with a loop
  • TelejesterTelejester Frets: 743
    I can't for the very life of me understand why orange made that amp without a loop and it's the very reason I don't own one.
    It's the way the amp is designed. To use that kind of MV and overdrive arrangement - which sounds more like power stage overdrive - precludes a loop... at least to make it worthwhile.
    The Dark Terror does have a loop but it's a more conventional preamp-distortion amp. It also needs two extra valves so it costs more to make.
  • John_AJohn_A Frets: 3775
    Same as the Mesa Transatlantic 15. It's not a design flaw as ICBM points out.  It can be done though, but probably wouldn't sound ideal
    http://www.ebay.co.uk/itm/GMRspares-Orange-Tiny-Terror-Effects-Loop-Mod-Kit-/262435044203?hash=item3d1a58fb6b:g:Lc4AAOSw3mpXNe46
    You can certainly do that, but the loop will be before the bulk of the distortion so it won't fix the problem, if the problem is delay/reverb etc being distorted...
    anyone who buys that kit and drills holes in their amp to fit it is going to be a bit pissed off.
    There's only any point in a loop if it does put the effects after the distortion - there are even amps with factory-fitted loops which get this wrong, and not just those with PPIMVs, like Matchless - the Soldano SLO is a good example.
    As Cabicular said, the best way to deal with it on something like the TT is a wet/dry set-up or a load/re-amp system. Not the cheapest or most convenient solution though.
  • peteripeteri Frets: 1284
    And also why the Dark Terror sounds like pants in comparison (sorry if that's a bit harsh, but it really disappointed me after the TIny Terror)
  • bloodandtearsbloodandtears Frets: 1703
    mine has one, I bought it from @benmurray85 .. not sure how it was implemented but it hijacked one of the speaker outputs in the process it seems..  When I use the loop I run the amp clean using dirt pedals up front and it works for me...
    My trading feedback
    It's just a very different amp really - for different players and sounds.
    How different does it sound from putting the effects after the dirt pedals in front of the amp? Just curious really - there may be *some* difference, since the level will be higher and there may be a bit of difference in the frequency content. It's not really why most people would want a loop, though.
    If you are running an amp clean there really is no difference whether you use a loop or just put your delay and stuff after the dirt pedals.  Using a loop just means you have 2 extra leads to set-up
    that may be so but using the loop means I have the flexibility to use the amp's drive and eq if needs.. I also but an EQ pedal in the loop to optionally adapt to said changes.
    My trading feedback
    never tried it because of reasons above..  its not a pure clean pedal platform as you know...
    My trading feedback
    bloodandtears said:
    never tried it because of reasons above..  its not a pure clean pedal platform as you know…
    Not at all :). I was just curious really, as to how much difference it makes when the amp isn't "distorting" - although I would agree that it always is, a bit. It's hard to get a pristine clean sound out of them at all... that's not what they're for.
    Interestingly the Hard Wired version does seem cleaner, once of the reasons I much preferred it - and as you know I am not anti-PCB at all.
    I guess I never really considered the all the pedals up front method as the done thing... but then I am new to the pedal and amps things...  I certainly don't own or want an amp that would just be a clean pedal platform though.. I like to consider an amps own drive and gain stack as a feature
    My trading feedback
