Why are you doing it, if you don't mind my asking? Have you run out of outlets on the PP2+?
it's for the V2 Kingsley Minstrel that I have and another Kingsley valve pedal sometime later.......
the Minstrel could be run via TWO I/puts on the PP2+ but Simon from Kingsley dose not recommend it
I've got the same problem trying to power a couple of Kingsley pedals on a board too. Maybe ditch the PP2+ and look into these...
http://www.strymon.net/products/ojai/
http://truetone.com/power-supplies/1-spot-pro/1-spot-pro-cs7/
You can power two Kingsley pedals and daisy chain most things off one tap. Each one has a bigger brother (Zuma and CS12) - more outputs/different voltage options etc.
The Strymon Zuma and Ojai are not in the country yet, but I think the True Tone stuff is readily available.
Brad
if the courtesy gizmo can handle it I don't have a problem
I already have a two strip in place and one position is for my Minstrel
this from Simon at Kingsley.....
Jouster needs around 6W and the Minstrel V2 around 4.5W, so lots of power to spare from the courtesy outlet...
Q: I have a PP2, PP AC and PP Digital.
I currently have mains AC connected to the PP2, which then feeds the PP AC via the aux output, which then feed the PP Digital via the aux output.
Noting the PP2's aux output 200W maximum load, am I likely to be able to exceed this with pedals connected to all the outputs of all three PPs?
A: That's fine (even with a few more supplies too). Yes, you can use the AC courtesy outlet as you have described.
And, you could still connect a power strip to the courtesy outlet for use with multiple pedals/effects and their adapters.
Just be sure to keep the power strip as far away from other pedals as possible as the AC can cause some ground noise if close in proximity.
