The first & last Marshal I used was a Master volume 100W, around 77/78. I've used Fender, Burman, Boogie, & Fuch's amp's, since then.
I have Inherited a TSL100 Head + cab, & not sure what to expect, so can anyone advise on the Pro's & con's of this model?
(I know about the footswitch problem already)
Then I'll decide whether to keep it, or move it.
Thanks,
Pros - the cab will be OK.
Cons - the amps sound thin and buzzy, and have a tendency to catch fire.
Always the optimist.
Clean channel can do 'marshall' clean up to nice broken up hendrix bluesy tone.
Channels two and three are gainy and fat, not the best marshall tone by a long way but good enough.
They're super cheap too.
I know they have a rep for going wrong a lot but mine was ok... apart from the the relay switches... and the valves went...
Just a bit bloody big these days IMO but if 100w heads with 412 cabs are your thing then there decent enough, especially for the low prices you can get them for now.
OLD dsl50 head is better though IMO tone wise.
PA Hire and Event Management
I had experience with no less than three of these when they first came out.
Why three do you ask? Well they all went back under warranty because they all broke in some magical way or other.
#1 - I'm not sure what happened to this one - I think the board fried itself in a not so spectacular fashion.,
#2. Footswitch died, replacement footswitch arrived and didn't work so the entire amp went back
#3 - Went up in smoke - If I remember rightly there really was smoke too.
That was 3 amps in less than a year. For what was meant to be their flagship amplifier suitable to gigging and touring it really wasn't suitable at all.
Oh it sounded rubbish too. Nothing like a DSL (and I don't mean that in a good way)
Personally I think they're shit, but some people do like them.
They aren't regarded as being Marshalls finest hour. In fact the TSL kinda spawned all the junk that followed. They haven't made a good amp since.
(Actually to be fair, the vintage reissues are great.)
I've actually got one in the house now, been storing it for a friend for a while. Never been tempted to turn it on, I remember what it sounds like
They also have a tendency to arc through the thickness of the board - often the board literally catches fire. And then there's the bias runaway problem (I've got one in the workshop right now with that), bias failures caused by the jumper connector to the adjuster board, the band-aid cap on the fourth power valve which still occasionally blows even though it's 500V-rated (because excess spike voltages are being developed there somehow), the stupid and unnecessary switching point in the 16-ohm speaker jack which blows output transformers, not paralleling the contacts in the 4/8-ohm selector so it goes iffy, the footswitch problems… it just goes on and on. And that's just the *common* faults!
Seriously, if you've acquired one and it's in full working order now, get rid of it before something goes wrong since it will most likely cost a lot to fix.
Jeebus
ive only ever seen them in hovel like rehearsal rooms but the sheer amount of controls on it made me unplug it and stick a tiny terror on the cab
And that's just the TSL100 - the TSL60 is even worse, unlike the DSL50 which is the same as the DSL100 but with smaller transformers and only two power valves, the 60 is like a larger DSL401. It sounds terrible - thin, weak and gutless. In fact I'm not sure that the 401 isn't fuller and louder.
