Yes, could be done in a combo but I wouldn't recommend it. "Auto" transformers as these things are known are notorious for a large stray hum field and there is every chance it will couple into the existing OP transformers or/and other wiring. It would also make the amp quite a bit heavier.
Use an external traff of about 10% higher rating than the amplifiers MAINS CONSUMPTION! Not the rated power output. Plaster the amp with "110 VOLTS ONLY!!!" stickers. In fact if other bods are likely to plug up your kit, take the mains fuse out and sort it yourself on site. That said, a Yanky VALVE jobby usually just blows a fuse on 230V and suffers no ill effects. This is NOT the case for solid state gear!
Bloody 60Hz Imericans!
Dave.
Many have extra outputs on the mains transformer to allow you to rewire to 240v
In fact this would be possible for most of the amps I've owned
I have had a Victoria, a Badcat and a Fuchs rewired for 240v, it's a 30-60 min job
There are some amps where you are supposed to use more capacitors on 50Hz, Matchless I think
I think almost all Matchless can be rewired to 240v
The advantage of mounting it properly in the amp - aside from stopping anyone plugging a 110V amp with an IEC socket directly into the UK mains, which I have seen done several times, occasionally blowing the PT - is that you can wire it properly so the stepdown transformer is on the downstream side of the power switch.
It might be tricky in a head though, unless it's something where the box is miles too big for the chassis.
Hi, Tone Control,
I also want to rewire a Bad Cat Mini to 240V. I put the Black and the Brown/White cable of the main transformer together, to get both coils serial, but it doesn't work (the 1 Amp fuse (240V) broke). Can you help me? I saw a scheme of the amp with a 220uF/350V instead of a 22uF/350V and a picture of an European Version with a "240" handwritten by Bad Cat even on this Electrolytic Capacitor. Could this be the Problem?
