Replacing the speaker is not going to reduce noise. You have probably swapped a good, old ECC83 for a new noisy one!
Dave.
Yes, it's as easy as unsoldering the old speaker and unbolting it, then putting the new one in the same way.
The speaker you need is 8", 4-ohm (not 8-ohm) - the most commonly available ones are Weber.
You had the cap can replaced at any pount yet?
http://www.lean-business.co.uk/eshop/wgs-g8c-20-watt-8-guitar-speaker-4ohm-p-2096.html
