SOLD: Peavey Bandit 112 Transtube Series Combo Amplifier, 80 watts,
guitarman66guitarman66 Frets: 29
edited October 2016 in Amps £
In mint condition and has never been gigged. This amplifier was purchased as a back-up for my Peavey Valve King and has had minimal home use only; now retired from gigging so I no longer need a back-up. The amp has two channels (labelled 'Clean & 'Lead') selected via the supplied footswitch and is rated at 80 Watts into the internal 12" Peavey Blue Marvel speaker. Features are as follows:
Front Panel:
Clean Channel: Controls for Volume, Low, Mid & High + 3 switched voicings: Vintage/Classic/Warm
Lead Channel: Controls for Pre-Gain, Low, Mid, High & Post-Gain + 3 switched EQ/Gain voicings: Classic/Modern/High Gain
Master Controls for Reverb and Volume Boost (either with control knob or footswitch to increase volume by 0-10dB)
Rear Panel:
Power Level switch: 3 power level settings: 25%, 50% & 100%
External Speaker jack
Damping switch: 3 settings for damping level adjustment
Effects loop: Mono send & return jacks
Remote switch: Jack connection for footswitch
Speaker simulated direct output: Output jack & volume control
Dimensions: (Height x Width x Depth): 17"  x 19.4" x 9.25" / 43.2cm x 49.2cm x 23.5cm
Weight: 24.5lbs / 11.13kg
Still under the Peavey guarantee until 29th May 2017
Collection only from West Oxfordshire, 12 miles from Junction 15 of the M4. Please PM me if you are interested or require further information
  • OK, it will never be a valve amplifier but the three switchable output power levels mean you can dial in a surprisingly good tone at reasonable volumes.
  • Bump
  • Weekend bump
  • bump
  • jonnyburgojonnyburgo Frets: 12431
    Forgive me if I sound like a dick, but you may want to review your price. Old USA bandits typically change hands for around £50 - £60 on here. Best off putting it on eBay where you may get a bit more. Of course it's up to you what you ask for it.
    "OUR TOSSPOT"
  • Forgive me if I sound like a dick, but you may want to review your price. Old USA bandits typically change hands for around £50 - £60 on here. Best off putting it on eBay where you may get a bit more. Of course it's up to you what you ask for it.
    Hi jonnyburgo,
    Thanks for your comment. However, this is not a beaten-up Peavey Bandit with a clapped-out speaker that has been gigged to death as you can see from the pictures above. As stated in  my description, I bought it as a back-up amplifier in case my Peavey Valve KIng broke down during a gig but it was never needed so it sat at the back of the stage in it's flight case every night and then I took it home again. The Bandit is still under the manufacturers guarantee and has had around two hours use at home and I doubt whether the speaker is even 'run in' yet. I'm quite prepared to do a deal around the £100 mark if anybody is interested and wants to collect it. If it doesn't sell then that's OK but I'm not giving away an almost unused amplifier in mint condition. By the way, I have already sold the flight case separately.
  • PRICE DROP £100
  • Bump
  • Bump
  • Another bump
  • Any interest in an 'as new' amp still under the manufacturer's guarantee?
  • ICBMICBM Frets: 72709
    It's a great amp for the money.
    To be honest I would sell the Valve King instead (assuming you haven't already) and keep the Bandit. I honestly think it sounds better, as well as not having the potential reliability issues. The VK is not brilliant by Peavey's standards either for tone or build quality.
    Used to jam with a guy who played a vk, always thought it was pants. Much prefer my bandit!
  • Bump
  • Price dropped again to £85
  • Bump
  • *** SOLD ***
