So - I finally managed to find a mark 2 - got it home today and it didn't sound great - petty sure it's the heat and the transistor combination - it was a hot day today and I used the pedal upstairs in my den - upstairs stays hot in the evening after a hot day - probably got close to 30 degrees - the pedal sounded intermittently spitty and faded on held chords/notes - battery tested fine - because I'm new to fuzz I haven't experienced heat effects on transistors so am a little concerned - I believe from what I read that steve's pedals are really stable - just wondered what kind of temperatures would normally cause this?
If you are new to fuzz then you might also be trying to use it too moderately. Fuzzes sound best with the gain past 1 o clock, when you learn to use it with that level of gain then your brain "gets" that it's how you are supposed to use it and it adjusts accordingly and starts sounding sounding normal.
Keeping the pedal in a drawer out of the light overnight seems to work fine cooling it down during these random British summers.
i suppose it it is very much true to the originals.
Anyway, on the whole they don't require fridging, just when it gets into the extremes of our temp range for a prolonged period. Btw germaniums are that sensitive that if you hold them whilst measuring their gains, you can see them go up as they absorb heat from your fingers.
