Does the T. rex chameleon power a Strymon Flint ok?
mattdavismattdavis Frets: 841
Hi all - the specs say it should be fine but have been reading some posts in the interweb where people have commented it can be a bit temperamental. I know strymon pedals are precious little beasts.
Can anyone confirm that they have used a T. rex chameleon to power a Flint (and 4 other 'normal' pedals) without a problem - just before I do a trade with a fellow Fretboarder.
Cheers for any advice
Matt
  • longilongi Frets: 95
    I run a Korg AX3000G which has a start up current of 600ma and running current of 350ma and it runs that fine if that helps at all.
  • mattdavismattdavis Frets: 841
    That's interesting @longi as I thought it had max 300mA per output. So the Flint should be ok I suspect... Ta
  • JalapenoJalapeno Frets: 6398
    full spec on line
    Feedback
    Jalapeno said:
    full spec on line
    I've had a read and I can see on paper it should work but various comments around saying it sometimes doesn't - just being pathetic and wanting to see if someone had specific experience of running a Flint of the Chameleon. I shall probably just grow a pair and give it a go :-)
