Trigger's Broom...
HarrySevenHarrySeven Frets: 8033
Forum feedback thread.    |     G&B interview #1 & #2   |  https://www.instagram.com/_harry_seven_/
  • axisusaxisus Frets: 28348
    I never trust an item that has 'copy>paste' text.
  • richardhomerrichardhomer Frets: 24858
    I need the number of whoever modified the neck pocket - clearly a master craftsman to have made it appear that unnoticeable....
  • meltedbuzzboxmeltedbuzzbox Frets: 10340
    Pretty sure that's a mij neck
  • It says 38mm nut - that's tiny isn't it?
  • john_rjohn_r Frets: 131
    Neck plate is all wrong, too far back from the edge of the body and should be a 3-bolter, maybe it was converted to 4 bolt and the plate moved but in that case the neck must have been re-drilled!
