Potentially stupid question re: Boss OC3
Been playing around with a second hand OC3... works fine as far as I can tell but the red light is permanently on. Is this normal or have I managed to FUBAR it already?
_______________________________________________
Still learning...
  • m_cm_c Frets: 1247
    The red LED should only be on, when the pedal is physically switched on and plugged in.
    Does the effect stop when you press the pedal?
  • JezWyndJezWynd Frets: 6118
    Light should only show when effect is in action.
  • Cheers guys - dodgy PSU issue. Swapped leads and it seems fine now.
    Still learning...
  • DesVegasDesVegas Frets: 4612
    Possible thread title change needed
