NPD Gurus 1959 Double decker
TeetonetalTeetonetal Frets: 7815
I've been after one of these since they came out at the end of 2015. It's a Valve based Marshall in a box, 2 channel + boost pre amp  / distortion pedal I suppose. It also has a direct out with cab emulation and a built in FX loop that can be series or parallel for those time when you go direct out and what the fx into FOH.
I've bought it mainly as a small backup to my main giging amp, a Brunetti Pleximan.
First impressions are:
Floor 2 / channel 1 is stunning. Great low gain breakup that is touch sensitive
Floor 2 / channel 2 is a bit dead, like I find most distortion boxes to be
The clean boost does what it should.
Not tried the emulation etc out yet...
Seems well made, but I wish expensive pedals would have metal instead of plastic knobs.
Bought from guitar guitar and the box looks like they played football with it. Ripped, torn and generally battered.
  • TeetonetalTeetonetal Frets: 7815
    This pedal is awesome. Without doubt the best amp in a box type I've ever had.
    A quick demo (using helix as the cab)
  • johnhejohnhe Frets: 191
    The pedal looks absolutely fab. I'm not sure I need the clean boost or the modern channel, but the vintage, lower gain channel sounds superb in any demo I've listened to.
  • Floor 1 really is superb. Though floor 2 with a strat is also a really nice sound.
    The 2 floors overlap a bit so you can set floor 2 to be a natural solo from floor 1 if you choose.
    BTW floor is what gurus term the 2 channels.
  • Patrick, it IS a gorgeous looking pedal !
