What do you recommend?
I'll be getting separate security for storing the bike at home so looking for something portable that can preferably be attached to the bike when not in use.
Cheers
Just GOOFFLED and they are called wheel/frame locks over there and cost in the order of £25. A hefty chain will cost at least as much and then a decent padlock on top. Even so a determined tea leaf will come tooled up to get what they want, all you can do is inconvenience them and discourage the casual shit-leg.
Just a lat entry, this link might help
http://thecyclingdutchman.blogspot.co.uk/2015/05/the-convenience-of-dutch-bike-lock.html
It's heavy but will ward off everything but a quick-cut.
Its also rubberised to protect the frame.
Basically if you want security it comes at the expense of portability. At home a ground anchor and heavy chain are the way to do it.
You won't get absolute security, you just need your bike to be harder to steal than the next one.
http://www.thefretboard.co.uk/discussion/comment/1100279
Trading feedback: Previous (+18) and Current
Normally the advice is to use two locks of different types because it will probably mean that a thief might need two different tools. For instance a hydraulic bottle jack can pop open a D lock, but is useless against a cable or a chain.
I have a good D lock, and a cheaper cable lock with a padlock. My bike is nearly 9 years old now and doesn't look as pristine as it once did so that probably counts in my favour as well.
With a D lock, the most secure way is to get a relatively small one so that someone can't get a good angle to pop it, but you need to compromise somewhere because it needs to be big enough to fit around a post.
It's going to be kept in the house until I can sort my shed out - needs windows boarding, decent padlocks, replace screws with bolts and a ground anchor fitted before I'll even consider putting it back there. Need to finish putting leccy into it so can install security lighting and an alarm as well.
I ended up buying one of these and I've still got a bike, https://www.amazon.co.uk/gp/product/B008QTKVO2
Not the most portable, but I leave mine behind at my destination so I don't have to lug it about.
When I was cycling I had a big old D-lock (might have been the Granite jobby) that I used to pop in the rack bag. It was so heavy you could feel the balance of the bike change, especially when cycling uphill and out of the saddle - the side to side sway of the bike felt very different (and unsafe, lol) when I had the lock in the bag.
Still have the lock - it's been keeping my ladder secured to a concrete fence post outside my back door for the last four years. The ladder has never been nicked (a small miracle on my estate) so it was a good investment
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
Nil Satis Nisi Optimum
Serious bike thieves will always find a way
I've got a cheapish bike a Kryptonite and two cheap chains. All three go on the stand or rack. IMHO the combination (sic) of three locks securing a sub £500 bike is hopefully too much effort for little gain.
I don't think the one I ordered includes a cable but I wouldn't expect it to be rated to anything if it did!
The frustrating thing is you try and get a bike as light as possible and then end up carrying a backpack with two heavy duty locks in.
I've also registered all of my bikes with the police. I also bought some anti theft stickers from the same website.
www.bikeregister.com
Hopefully this acts as some form of visual deterrent.
