http://www.screwfix.com/p/lap-13a-2g-sp-switched-socket-3-1a-2g-usb-charger-brushed-stainless-steel/4962p
socket in a radial - 2 sets of wires
socket at the end of a spur - 1 set of wires
socket in a radial, which has a spur taken off at that point - 3 sets of wires
You can see that there's the possibility of up to 4 earth wires needing to be connected. Hence there's 2 connection points.
Im my bedroom I had a single socket with single earth and replaced for double socket with double USB ports. I had some twin and earth cable left from another DIY job, I cut out a strip of the earth used some earth shielding tube and slipped it over the strip of earth and bridged the two earth terminals in the new socket back to the earth lead of the incoming supply so that if either socket or usb needed to discharge to earth they could.
Again im not saying this is the correct way to do it and im not suggesting you do the same im merely telling you what i did in this situation.
You can fit the new USB socket to this, Red/ Live, Black / Neutral and earth in either of the socket earth terminals ( they are linked internally)
Your other sockets have 2 x twin and earth cables?...same connections, you can split the 2 earths onto separate terminals if you want or stick them both in the same one.
Beware - some cheaper usb sockets are very deep and you will struggle to get it back, others have a spacer ring with them to give you a bit more depth.
https://twitter.com/spark240
Reddit r/newmusicreview
I bought this.. http://www.hotukdeals.com/deals/optimum-4-usb-mains-charger-b-m-store-4-99-1693491
http://www.argos.co.uk/m/static/Product/partNumber/5589612.htm
