You cannot have an earth loop unless two pieces of equipment have a mains earth and are then connected together by an audio cable that ties both signal earths together.
If that is the case did you reproduce that setup at mates?
My worry would be more that the rehearsal room does not have a mains earth at all!
Dave.
Did turning the guitar down stop it?
This is probably obvious, but did you have the amp turned up as loud at your mate's house?
That is the kicker. Often people don't run at home nearly so loud as at gigs or practice.
Many a time people use an 5, 15, even 20W amp at home and are staggered at its loudness but when they get into a decent sized room and with a bit of competition from a drummer the amp seems to shrink in available welly! This is most evident with solid state amps because they have a well defined overload point past which they sound horrible.
Another variant on the scene is the perhaps seasoned gigger who gets into home recording and is staggered at how noisy his beloved (insert amp/guitar) combination is!
Dave.
it was a smaller room we usually have about the size of your average house double bedroom - it was very cosy
I heard from a guy down the market they are working on an EMP weapon to disable automatic doors at supermarkets.......
The only way to record guitars was to orient yourself in a particular direction and then don't move!
I suggested a personal Fariday cage for recording guitarists might help but I don't think they ever tried that. It was a pretty small studio so there wasn't a lot of space in the live room - maybe something like the 'pods' from Spinal Tap but made out of wire mesh would have fitted? I'm not sure being shut in a tiny cage would have been conducive to a relaxed performance though but you could always leave your guitarist locked in there to stop them trying to turn themselves up during mixing.
Or is that a stupid idea that couldn't possibly work?
It's exactly the same principle as screening a guitar, just on a larger scale.
I once read a great interview with Chris Rea where he was talking about his endless battle between single coil pickups (which he finds necessary for his tone) and rf interference at venues. He said the only place he ever played a gig where he didn't have noise issues to a greater or lesser degree was when he did some event in the Kremlin. Apparently, the whole place is a giant Faraday cage to stop foreign spies eavesdropping.
Mind you, he was talking about a time before the most of the planet was saturated with wifi.
