I was looking around at looper pedals to give me some options for building a bit of a jam up.
Im a home player, with a THR10c, a Tele and LP. I love the tones I get from the THR, especially when I link it to the PC to get access to the compressor and room reverb.
I initially looked at a Boss RC3 as it's the go to looper but as I don't need an overcomplicated setup, I then saw that Zoom were doing the very affordable G1xon with a looper and as an added bonus, it was an effects pedal too! Then I started looking at G3x on eBay and I can get a used one for only a little more.
The THR doesn't have an effects loop so if I'm looping with a dedicated looper then I can only use one sound throughout whereas with one of these effect pedals, I can setup separate channels so I can lay down a clean rhythm and then drive it a bit more for a solo.
Is it worth going for the g3x or is there a better alternative for the money?
I'm a big fan of the G3x for the effects in it but the looper is a bit of a faff to use. Particularly if you want to switch between the looper and effects.
If you are using a PC anyway, why not build up your loop in ableton or something similar and noodle away over that?
Alternatively, TC Dittos can be had for pretty decent money now.
It does seem like the g3x is the defacto go to budget fx/looper option though.
The G3X is excellent value for money when you consider all of the stuff it has in it. I originally bought mine to use as an amp modeller (into a hi-fi amp, and then into two 1x12 guitar cabs). When I changed amp, I kept it and put it in the loop to use the compressor, vibe pedal and EQ. I recently added a couple of modulation effects that I don't use much. (Comperssor and EQ are on all the time, and the vibe and other two effects are mapped beside each other, so the three footswitches are used for them.)
Even if you start by using it as a looper or whatever, and then change to something else, there's a good chance it can be reused for a different purpose.
Nomad
There's a lot of effects on the G3x I can see myself never using but some of the reverbs and delays seem to be very good.
