Not sure if this is a dumb question or not, but I'll ask it anyway.
Would using a stereo pedal like the Fulltone Supa Trem 2 going into Reaper, using amp sims, make a big difference to the sound? So basically there would be 2 tracks, each with an amp sim on to emulate the stereo coming from the pedal outputs. Would this be true stereo, or some weird mono/hybrid version that wouldn't really add much?
Essentially, I want to know if the Supa Trem 2 (or something similar) actually needs 2 mic'd up amps to do the job, or if it would work in an ampless scenario.
Stereo pedal - it depends how it applies its stereo effect. I dare say, stereo pedals are designed typically for a live situation with 2 amps, not necessarily to sound great when recorded as stereo. So it would depend on the pedal concerned.
You mention amp sim, then later you mention 2 mic'd up amps - do you actually have a decent amp to mic up, or are you going to use a software amp sim? I'd have thought to use an amp sim vs mic'd up amps is a separate issue to whether to split into stereo or not. Remember you could always record direct into the DAW then "re-amp" each channel in turn, using the same (or maybe slightly different....) amp settings, mic'd up suitably.
The bit I've highlighted - 1) there is no emulation of the stereo - the stereo is real from the pedal, if its used! Secondly an amp sim doesn't do this "emulation" anyway. An amp sim is mono in, mono out, isn't it???
I'm really trying to find out if there's any advantage sonically to buying the Supa trem (or similar) or if just using two tracks and splitting my mono signal is basically doing the same thing?
I'm not much of a mixing engineer so just like what I find easiest!
If the former then there's a point, if the latter then splitting inside the DAW will be the same but cheaper.
Nomad
