Mullard stated using that logo in 1971 approx. There should be a 2 line code etched in the glass somewhere .. First line will be xf and a number, next line will be a mix of letters and numbers starting with B .... if you post that we can date them to the week for you ...
Value will depend if they have any life left in them i.e. they really need test results and also what number follows the xf
B3K4 or 83K4
If the silver getter flash at the top has stated to go thin, semi-transparent, or pinkish around the edges - that's a sign the valve has been leaking slightly, although it will continue working until it's all gone.
If the grey plates have "ribs showing" - horizontal lines in a discoloured patch in the middle - that's a sign the valve has been running far too hot, the lines are the shadows of the suppressor grid.
Valves with either of these signs may still work, but they're on the way out and worthless. If they don't, and look visibly in good condition, you then need a tester.
*Don't* try to clean the outsides of the valves, unless you're very careful - the print is very fragile and is easily rubbed off, which devalues them even though they work just the same. In particular don't wipe them with anything damp, or breathe on them and rub the glass - you'll take the printing off immediately.
ICBM on one of them, there's silver going down the side of the tube?
If so that's another less common sign that the valve is knackered - it's evaporation/deposition from the grids having been run far too hot.
But in any case, if replacing them with modern valves gave a big increase in volume, they're ***ed. It would be the other way round if they were in decent condition.
I had a look at the pic of the amp you posted originally and at least a couple of them do look very thin around the edges of the getters too.
This is quite a pretty feature of the valve that you don't get with new ones.
I do like aqua corrosion green.
https://scontent-lhr3-1.xx.fbcdn.net/v/t1.0-9/14222264_10153896581297066_1494064876923659944_n.jpg?oh=00fd0debf3323b7d960b39cb0925d379&oe=587DA960
And the weirdest thing is- the more you engage with the forum knowledge giants like the lads who've posted here on thos very thread, the more you learn and the more you, in turn, can pass on to others.
