Anyone know when they're releasing those tube pedals they also showed at NAMM?
The Friedman website has no mention of any other pedals yet, so I presume they're some way off production / distribution?
Not everybody will want compression added to their dirty sounds, although it's only really with high gain that you get that.
These are two separate pedals, so I won't necessarily use both together anyway.
With regard to the Sir-Compre, the gain is really there to add a little grit and overdrive, should you want it, rather than all-out distortion. Its scope can be set via an internal trim pot. http://friedmanamplification.com/manuals/SIR-COMPRE_INSTRUCTIONAL_MANUAL.pdf
https://youtu.be/rZhWG8FqDlA
